Installing windows 10 os using USB drive help
Arucard
Installing Windows 10 OS using USB drive, I am currently using Asus B350 Prime plus with the latest bios 1002
My question is if I buy a 64gb capacity to use to install the OS , the mobo can detect it?
Secondly which brand and model you guys recommend , reliable long life most important which everyone hopes for besides actually I am using for other stuff too.
Thanks a lot ! :o
spiky0180
Can detect. Just set boot sequence in the BIOS.
No need to get 64gb. Because once you convert it into a winOS installer, you cannot use the thumbdrive for anything else. Just get 4gb enough.
Brand wise doesn't matter. I using cheap no brand thumbdrive that I get from attending conferences as a OS installer.
royfrosty
Can use the thumbdrive. Nowadays for windows 10 iso can be created by windows media creation tools software. They dont make it into a os installer. Im still using my 128gb thumbdrive with windows 10/pro/N in it at the same time using it as thumbdrive.
ZrE0_Cha0s
Well actually the minimum amount is 8GB. Did burn in to my 4GB thumbdrive. But they daid not enough...
kamipify
no need la just use any one that find at your house one can liao
i am just using a usb 2.0 8 gb only
commach
I think i try before my 4gb trumb drive , cannot work I remember not enough space :(
My Windows10 USB installation drive.
commach
Just get a USB3 8GB/16GB Ultra Fit (small physical size) as the USB installation drive and avoid using it as data storage/transfer drive to avoid virus transmission.
I don't use O/S installation drive as data storage/transfer, once installation done, chuck it one side hence I seldom use more than 8GB for O/S installation.
Brand and write speed doesn't really matter much since we are not using it as storage, any USB3 thumb drive can give you decent read speed as an O/S installation drive.
Arucard
Ok , I wasted too much dvds to burn those OS :( , now use USB drive faster and save dvds
ZrE0_Cha0s
This is incorrect.
4GB for 32bit or 64bit, 8GB for 32bit and 64bit.
See the different?
ah no wonder that's explain why they required 8GB thumbdrive. :s13:
cos i just download the iso as per normal not regarding of the 32/64 bits =:p
undead102
I check my win 10 pro 64bit iso only about 3.1Gb so 4gb thumb drive should be enough already ba.
Ah Ken
U can use the Thumbdrive for other things as what others mentioned. If u not confident with it, perhaps u can just add in those motherboard drivers inside as a folder for quick access if needed. Right now the lowest capacity u can get is probably 8GB at $7.90 liao
ZrE0_Cha0s
Damn....that price is almost 1Gb=$1 totally not qorth, like really just go for more than 8Gb.
Arucard
anyone can recommend which sandisk usb 3.0 thumbdrive is good ah ?
Good read and write speed
shadow84
If the thumbdrive is reformatted to act as installation drive, will it get cranky if we put other stuff inside? It would be similar to putting additional stuff into a Windows CD.
DynamiteZerg
No it will not get cranky. It will just ignore the extra contents unless you modify the installation script etc.
