Intel Ethernet Connection l217-V Problems
m.garz
I'm not sure if anyone has experienced this problem before.
Every time I boot my PC from Shutdown, I cannot connect to the internet. I need to disable/enable the Intel Ethernet Connection l217-V Adapter or wait a few minutes to have internet connection.
This only happens when I shutdown my PC; it does not affect restarts.
My specs are listed on the right --->
I'm using a CAT6 cable and did not have this problem before. This started happening when I reinstalled my OS to troubleshoot my previous GPU (RIP gtx 760).
I have re-installed my latest mobo and Ethernet Connection drivers but to no avail.
Any help would be greatly appreciated.
Cheers!
Update: Windows 10 Update Fixed it :)
ahwei91
Maube can try to disable fast startup in your win10 power options.... some drivers might not load properly with fast startup....
Koenig168
12.15.xx.xx 7/1/2017 drivers. Is there a 22.9?
You can thank Windows 10. The updates broke ANS for driver versions prior to 22.3. You can download 22.9 from Intel as per below.
m.garz
Thanks for all the help guys. I have installed the latest package 22.9 with Ethernet Adapter Driver 12.17.8.7, 9/29/2017.
But it's still not working. I do not want to re-install my OS again because of this. **sigh**
