iOS 7 issues
chottohen
Anyone's mail app having issues? Keeps giving me "connection to the server failed" error message.
000kai000
just gotten iphone 5s... yes my chiong cable dont work for moi anymore :(
any sexpert can help moi? :(
camoguysg
I can confirm battery drain faster. Now when I play any games, the batt drops 2-3% every 1min :(
camoguysg
There is another bug not sure if anyone else experiencing it. Last time while typing and I press on any area to zoom in, I can see the blue cursor. This helped a lot when I need to correct a spelling mistake, punctuation or certain words. However, now the cursor is missing every time I "zoom" in. Anyone else has this issue too?
blimey
Same same
My iPhone 5 charges damn slowly after updating to iOS 7.
Used to be able to fully charge within 40mins-1hour.
Now 10 minutes only charge 5%.
that's not normal. i'm on 4s with ios 7 and i get from 30 % to 100% in about 30 mins.
i'm charging it via my thunderbolt display so that might explain the speed.
sandwicher
Any way to disable this? don't like it zoomed..
Settings --> General --> Accessibility --> Reduce Motion flick to On
Switch off your parallex to get it "unzoomed"
Or just use those photo apps your download for your instagram to add the borders?
xiaoken
Got the 5s. Some of my apps don't rotate anymore (splashtop, 9gag etc etc). Anyone got same problem? Any fixes?
WahjongKid
After updating to ios 7 on my ip5
During call . Sometimes the light sensor doesnt work
During calls . It will auto mute or activate loud speaker due to the screen unable to auto off
mlim650
I am not able to create a reminder in iPhone 5S. I upgraded to iOS 7.0.1 today when I got it. I tapped everywhere to try to create a New List but nothing happens. Anyone encounter this issue?
Thanks.
Winston7222
Here's my Battery Life report after updating to iOS7 on my iPhone 5...
Would advise to disable those features/function that's not necessary for you usage..;)
Edit : FYI, I had Parallax wall paper for Lock Screen, Dynamic wall paper for Home Screen & Updates enabled.
tankib
no issue for me on battery ip5 user
100% charge over night can use 1 whole day
9am - 10pm with 30% left
4G on
Seem to drain batt on 4s after ios 7 updated. When reading flipboard, 1min down 1%. Last night about6 hours standby while sleeping, down 4%, i think, from 100% to 96%. Notice that when the batt go below 20%, the draining is very fast.
camoguysg
Another thing I don't like is the charging icon... Now no longer tell u that its fully charged. Formerly we had this plug symbol ... now it's always lightning even after 2 hoursl at 100%
maisianmaisian
yah this is one of the thing which i am disappointed at...
