iOS 7 issues
ragnarok95
Senior Moderator
Senior Moderator
On "reduce motion" to prevent your wallpaper from zooming in or out.
ralliart12
I notice the default Camera app is unable to have the settings for HDR maintained across sessions. Previously on 7.0.2, I can have the HDR toggled on & this will be sustained everytime I launch the Camera.
argentinafa
it helps lah.
why dun u enable it and reset yr wallpaper again
Yup ok bros. I get and know that on-ing that reduce motion does prevents wallpaper from zooming in.
But what I meant was, there is still some degree of zooming in, as compared to default pic size, relative position of object being taken.
If u remember or can compare to an iOS 6 device, then the difference is clear.
argentinafa
Ditto. I prefer to be toggled on always too.
ralliart12
There is another bug not sure if anyone else experiencing it. Last time while typing and I press on any area to zoom in, I can see the blue cursor. This helped a lot when I need to correct a spelling mistake, punctuation or certain words. However, now the cursor is missing every time I "zoom" in. Anyone else has this issue too?
Encountered this in native & some other updated-for-iOS7 apps on iOS 7.0.2 previously:
when pressing & holding on some text area, the magnifying loupe appears, but unless you start to drag your finger around, the (blue) cursor will not appear. If I'm not wrong, this issue appears to go away in 7.0.3.
ekardo
latest 7.0.3 confirm drain more batt, cos my philips alarm clock can no longer charge it even though it's showing the charging status....
closing all apps and restarting phone yield same results...
ragnarok95
Senior Moderator
Senior Moderator
Ur battery might have problem???
Seriosuly i see no diff ever since 7.0.2 to now 7.0.3.
ForumRider
Maybe thats true. Before latest update to 7.0.3, the batt indicator is solid... End of day still at least 50%
Now not anymore... But again someone posted that batt indicator is just indicator.. It only shows the rough amt of batt left, not actual batt...
Btw i also notice that the batt life tends to be better if i use with apple original case. If i use PS bumper, the batt drop like crazy.... Wonder if i affect the reception and thus use up more batt..
fuzzybear
wow if this is true
apple so clever first is make all fake lighting cable can't use
and now this haha power
u mean the apple case the leather for 5s?
salac38
Hi, just wanna asked: i notice when i'm going to unlock my screen using fingerprint / password: there's a black glitch a while before showing home screen. Is this normal?
And I notice sometimes when I open either instagram or imessage, there's also a fast glitch but it happens once in a while
Anyone experience the same thing?
yeah... it's like for a 0.1 micro-second kind of thing as it transitions from reading ur finger print into the home page... but it is barely noticeable really and doesnt affect anything so i'm okay with it...
fuzzybear
Yes I mean the original apple leather case :s13:
Wow then I Better switch to apples 5s leather case haha
Might be only haha was going to hoot a real leather case cost $100++ haha
But 5s original leather cAse also looks good too just don't have any brand behind it haha
Actually I atil on 7.02 version
ForumRider
haha dunno is it me or wht... but i find batt drain better with the original leather case.
I m looking forward to next update...hopefully can fix most of the bugs and increase batt usage / efficiency:s22:
btw just to check if any one of you sometimes will get 3G connection? Sometimes while browsing internet or check email/ fb, suddenly no 4G connection..and the phone cant load anything. Worse is that it start to use up batt and drain fast.... :(
usually i would just go another spot and on/off 4G connection again. It works for me. :)
Not sure if you guys encounter this...
fuzzybear
This sounds so like laghub symptom
Haman
Not sure if u guys encounter this while using car charger while driving. Does your phone ring or give a message tone when u receive one? For example whatapps, when I charge my ip5s thru car charger and driving back home, I got a message but there is no ring tone, only vibrations. Is this normal? Can't find any setting in whatapps for notifications while driving..whatapps is confirm working if no charge thru car..
PetPet
Moderator
Moderator
Whatsapp is buggy at this point of time. wait for their update.
