iOS 9 jailbreak released
MoyoCase
in reddit its states that u should turn off the airplane mode and make sure u have wifi or data connection before opening cydia . Thinkthats the problem here for the cydia crash ... so remember to do that
it seems that i had a conflict with upgrading and my previous jailbreak method in ios 8.3 , so restored to new iPhone , ran the Jb again and now cydia loads.
nacnac74
I using Windows 10 x64 with latest Itunes
iOS 9.0.2 upgraded by OTA.
Using Pangu v1 and jailbreak will ease..
No issue so far as No tweak install :)
Same scenario as mine. Jailbroken done smoothly. Now waiting for tweaks to be updated.
KwayChup
Cannot be, I ran cydia with airplane mode on because I forget to off it. Still works no crashes
star77
there is a panggu icon on the homescreen after jailbreak?
anyway to remove the icon? I tried removed from 'installed' app in cydia but was not able to.
MoyoCase
Does removing it remove the jailbrrak anyway when I do the wiggling thing home screen I can see there is a cross appearing on the app
star77
Thanks. Mine had no cross earlier. After restart the cross came out.
I uninstalled and it's not affecting the jailbreak.
MoyoCase
good news is that swipe selection pro works on ios 9.02
however I cant see the app installed in settings
tried virtual home and it didn't crash the mobile substrate. still cant see the app installed in settingd
KwayChup
Means virtual home can use?
ERT
MoyoCase
how does the low power mode works?
if I enable this do I get WhatsApp or messaging apps notifications???
crunsik
has anyone tried to JB using Pangu 9 without updating to iOS9? ie, would the JB work if I am using iOS8.4?
Kusanagi
why would you use a JB for ios9 on ios8 when there is a pangu for ios8?
v0dka
u guys when using the jb software, is in english or chinese text?
KwayChup
Sweet sweet running virtualhome, never ask me to buy also from bigboss repo
