iOS 9 jailbreak released
MoyoCase
Got beta but cannot download, so using the one for iOS 7, quick unlock and long press doesn't work... Not complaining it since it's free
yeah just tried the ios 7 version, works but not all functions
KwayChup
Update : I install the VirtualHome 8 n 9 Beta already. Works flawlessly
KwayChup
Pardon me for spamming.
Important : Don't not install Medusa if you are using DBS OR UOB APP. It also causes other app to crash
MoyoCase
Yup read this too, surprisingly it's free of charge.
Not sure whether if it's due to me being paranoid or it causes drain to the battery.
in options u can set it to run max for 2 mins after screen off...
if u keep it always on permanently u will see battery drain though not sure how much
MoyoCase
does activator work yet?
is there switch for low power mode in activator???
Ev0d3vil
Okay jailbreaked, but where is Cydia ah?
Kusanagi
if its not appearing means not done right
i realized highest success rate is to do a back up of your phone first
then do a reset settings, then JB, activate cydia (off air plane mode) then restore the backup
