iPad Pro (2022)
tohchr
do u guys normally buy wifi only model or wifi + cellular?
For me, I got one sim card for tablet. So, I will always get cellular model. I do bring my tablet out to work or drinking coffee with friends.
hereiam7788
if get the celullar model, can just get SIMBA (TPG) 50GB plan for as cheap as $10.
which can compliment my zym (70GB) plan on my iphone. :p
tohchr
I am using SIMBA 50gb+50GBfree which work very well with iPad.
tohchr
How the speeds like? I believe they are on 4G but tapping on M1 or StarHub network?
I only played Clash of Clans and so I cannot comment on other games.
I used it to watch youtube videos, I had no issue at all and it does NOT lag as well.
All these are done in office as I do not take public transport. So, I cannot commend on the speed inside train.
hereiam7788
macbook air (m1) vs macbook air (m2) = price difference of $250.
while ipad pro (m1) and ipad pro (m2) = price difference of $50.
i supposed that it is still worthy to get ipad pro (m2) instead of sourcing for ipad pro (m1)?
tohchr
If u get iPad Pro M1 from lazada, price different around nearly $600.
tohchr
How to get $600 difference between m1 12.9 and m2 12.9?
Sorry, I never mention that I used the highest specs which is 2TB Cellular model.
The price for M1 in Lazada is $2927 after discount. For M2 model, it's $3574 on Apple website.
Parka
If you can get significant savings from the M1 model, it's still a good purchase because both are capable tablets that will do the same thing.
hereiam7788
Depending on how much cheaper the m1 model one can get I supposed.
take iPhone as an example, one iPhone can easily use for 5 years. So if iPhone 13 brand new one, one cannot get more than 20% cheaper than iPhone 14, it is still worth it to get iPhone 14 since u are going to have one more year of usage than 13.
I compare the refurbished iPad Pro 11-inch gen 2 (A12z) sold by Apple vs the m2 iPad Pro 11-inch now. Price difference about 33% cheaper for the gen 2. If consider an iPad can be used for 5 years, I should expect 40% cheaper price at least for the gen 2 to buy but it is 33%. If 6 years, then it should be 33% cheaper at least which is true but imagine that it is a refurbished set and not even a brand new retail set. It is not exactly real cheaper too.
So unless one can get a m1 iPad Pro for more than 17% or 20% cheaper in price than m2 else it is not really a ‘saving’ given that the iPad Pro lifespan.
hereiam7788
it may sounds a lot of saving but if u compare the % it is only 18% cheaper than m2 brand new. If u follow my calculation on the earlier post. The saving u get is just one year lesser of lifespan comparing to m2 if u are to use the iPad Pro for 6 years in total which it is not really a real saving.
skpuppy
Really thank you for buying this expensive product. Lol! 2TB device. I won’t even use it on my MacBook Pro
