iPhone 11/11 Pro
tohchr
I am not sure, that’s why asking. Hope those having 11 Pro Max can help verify whether theirs is also like that.
If u r not using case, it will be like that. That's why I'm asking u if u are using the phone naked and not u naked or not.
jaydos
Haha....I know what you meant by naked earlier. For my 11 pro max, it is “like that” when naked and with casing. So it’s normal I suppose?
cnt
WhatsApp is backup to iCloud. Check your iCloud storage and make sure there is enough space. Especially if you backup video in WhatsApp
tec_geek
Jirachi
Optimised charging has never worked for me since I switched to the Pro Max aka iOS 13.
XER
anyone knows if iphone is eligible for the no gst 11.11 sale at the Jewel?
waterballoon
XER is referring to the special 11.11 sale at Jewel where GST is absorbed. Apple is listed as participating merchant although dunno if iPhone will get GST absorbed or not.
Nope. Apple store doesn’t do discount. You can only get it from Lazada or Airport Depature Hall.
Ye_Rongtian
Anyone have 11 and 11 Pro max and feel the pro max is noticeably faster? I noticed it... when typing the pro max is faster whereas the 11 will lag a bit?
XER
kirium76
How do u guys check for dust in the camera lens? Use torchlight to shine to inspect and shake the phone to see if the dust, if got any, will show itself ? Kinda difficult to check even under shine torchlight leh.
Sent from Samsung SM-N975F using GAGT
RocketBunny
Just keep look from different angles. It'll be very obvious if there is dust underneath. After wiping still there means inside Liao..
