iPhone 11/11 Pro
ragnarok95
Senior Moderator
Senior Moderator
Will iphone 11PM charge faster if use the newer 20W as compare to the in-box 18W??
ragnarok95
Senior Moderator
Senior Moderator
shorty07
Anyone bought used iPhone 11 from shops before? Wondering if it will b wise to buy a used set. Buying for my daughter but don wanna buy new.
manofsorrows
Check that there is true tone. I ever kena before a set (iphone 8+) with no true tone. Very obvious the lcd was replaced before.
And then go thru the usual functional tests. Check for dust under the camera, shine a light thru the port and sim card hole,check for signs of water damage etc...
shorty07
how to check for true tone? i hv nvr bought a used phone b4. but since my daughter die2 want iphone n iphone 11 is not that old, i tot i could consider it.
manofsorrows
If you power on the phone and you see a Hello screen, Go thru the setup process, no need to key in apple id or passcode, there will be a screen to show you true tone display.
If the phone is already showing the home screen with apps, then go to settings, display and brightness.. check if the true tone option is there.
Glariel
For iPhone better don’t buy used if you don’t know how it function especially when there is iCloud lock. They can give you a usable phone but when you reset it will require the previous owner iCloud ID in order to unlock the phone.
shorty07
thks for ur reply. really helpful
shorty07
ar ok.....i nvr use iphone b4. seems a bit troublesome if kena this kind of problem :s22:
