iPhone 11/11 Pro
porky_88
u support me bo?
been using for two days... in and out of multiple pockets and jeans.. still perfect leh..
personal habit is that the pocket i put phone in don't have anything else.
Plus caudabe veil case really make the phone RAW... i like it RAW RAW RAW...
on a different note, psaj got screen cleanance for the TP SP? veil is like flush with zero lip clearance from screen.
watzup_ken
so all here use their iphone 11 with screen protector? No one RAW here?
If you are comfortable, you should just go ahead to use it without screen protector. People that I know that don't use screen protector are not concern about cosmetic damage. If you are particular about cosmetic damages, then you know what you should do.
watzup_ken
Nope
I don’t dare to use without screen protector
Problem is if you use shirt and wipe sure will have micro scratches.
Not sure if its the glass that is scratched. There should be a very fine anti finger print layer which may make it seems like the glass is scratched.
watzup_ken
OT a bit.... saw someone joined in 2018.. arch supremacy member....
me join more than 10 year still at the base level....
me need to go self reflect.... hahahahahahaha
How does that matter? Arch Supremacy member don't get any special advantage.
metamofia89
Nope
I’m quite torn with this. Zollotech’s (tech reviewer) Pro Max has a lot of scratches.
I’m going naked on my screen and so far it has been close to flawless. Only a small fine ding near the bezel area there. The rest, not even a single scuff mark.
metamofia89
I’m not using any screen protector since day one bro. Very satisfied with how durable the glass is. Last year, this time my XR was already quite scratched up.
But there are reports claiming the glass is more lousy than XS series. I can only speak from my experience and so far it has been great.
POPmyBULLET
Zollotech also mention no more eyestrains from 11 pro. He used to have it with the X. Is it true? Cuz I've got eyestrains from my xs max.
szeli
I had eye strain using my X. only got better after I disabled attention aware.
ApexMan
Diff ppls diff lor
I use ipx and now max pro no eyes stain
I play with note10 + I kana
But
S10 plus and now
I use max pro and a70 Samsung aslo amoled also no eye issue
