iPhone 11/11 Pro
tsipacse
Hi all sorry if this has been asked before but when i check battery in my iphone, it says that the hardwarezone app has background activity that consumes battery. Any ideas why? TIA
szeli
e app prob needs to be updated. swipe it away to kill it if e drain bothers u.
RocketBunny
phew thanks! were u a long time android user? I like to customise my phone w gestures etc. nova has made the experience really great so I'm not so sure if switching is right.
Nope.. using android as spare phone to do certain stuffs.
Oh then you better stay on android ba. :s13:
trento
finally got widgets and app library for ios liao. :D
after 10 years
PongRareRare
Anyone knows how to “shortcut”? Whether it’s possible to lower the notification volume when I connected to earpiece? Sometimes it is deafening
PongRareRare
I have been wanting the same too, but unfortunately there isn’t shortcut settings for the ringer volume, only for the media volume. :(
That’s sad, I’ve been playing around and google, like what you say, I can only set for media volume. And the “automation” isn’t really automated? It will create a notification and I’ll have to press it and run, did I miss any setting?
PongRareRare
Ok, I’ve thought of a way but I need some help as I can’t figure it out.
Automation:
1) when connect to earpiece (Bluetooth) - easy
2) media volume to 50% - easy
3) activate “voice control” to activate “mute sound” - I can’t make this happen
End automation
This will make phone in silent mode while media volume is 50%
I can activate voice control easily, but how to have it say “mute sound”?
Voice control is under accessibility.
Another will be opposite,
To unmute sound when I disconnect Bluetooth
Anyone knows how to automate step 3?
Edit: figured out how, doesn’t work, voice control doesn’t seem to listen to what the phone speaks
