iPhone 11/11 Pro
Bane147
Anyone brought iPhone from this website, Reebelo.com before? Can share your experience if you have cause thinking of getting an iPhone 11 there but never heard of them before.
Thanks!!!! :)
manofsorrows
But their trade ins are higher than the regular retailers ie rwm
Thanks!!!! :)
edrickmark
Which one you all will choose:
IPhone 11 Pro Max 256GB or IPhone 12 256GB.
I am going to re-contract next month. Currently suing IPhone XS Max 256GB
Please advise.
Thanks
Tyrian
Please advise.
Thanks
Depends on your needs and wants mate.
I’m using HK set iPhone XSM 64gb. Battery still 93%. Decided to skip this one.
ragnarok95
Senior Moderator
Senior Moderator
Please advise.
Thanks
It’s pretty obvious which to choose.
metamofia89
Please advise.
Thanks
iPhone 11 PM. This phone’s battery life is ridiculous. With iOS 14.1, I can safely say the battery life has gotten back to its best. Tom’s Guide did run battery tests on the iPhone 12 and the result is not as good as the iPhone 11 from last year. And that’s on 4G network too. Large screen in 11PM that can go up to 800 nits vs the 625 nits on the 12.
iPhone 12 and 12 Pro are great phones. But remember, the 11 PM is a very, very capable phone still.
*adiBOY
Please advise.
Thanks
Definitely the 12. Not only it’s one generation newer (you get another year of iOS update), the 12 is better in every way. It has OLED display now, thinner bezel, wide angle camera is upgraded, night mode for every camera (including front camera), Dolby Vision recording, night mode video recording and the weight is so much later compared to the 11 Pro Max.
Yes you lose out on the tele lens but most of the time, the iOS will use the wide angle camera to crop anyway so technically, you don’t lose out much.
ragnarok95
Senior Moderator
Senior Moderator
The 12 is better. The 11 pro wins by having tele lens, bigger screen, bigger battery. It’s still better to go for the 12. Just to correct that not everything is better in every ways.
