iPhone 11/11 Pro
mikeeeey
Yes I always get this even when the app updates at times, very irritating.
Only way out is to uninstall and install again
Thanks mate. Really just have to uninstall and install again to make it work
VodkaPear
Any multi plug charger to recommend?
Was using Anker powerport+ 5 but have pass it to my wife.
Looking to get the same but seems like bo production.
Search the web only found Anker powerport PD5.
Is the usb c able to support fast charge for pro max?
Or should I get another brand?
Attila
i mention in another thread but i guess i will mention here as well.
my new iphone 11 has a dead pixel, check for the screen for defects otherwise you will be wasting money on TG
*adiBOY
Why not get Anker PowerPort Atom PD 4?
VodkaPear
Saw this in US web
Actually thinking of getting this. Since I can use the 2 usb c to charge iPhone and iPad.
Not sure how much it cost as amazon also no stock.
And can't find it in local.
PetPet
Moderator
Moderator
I've read some issues about the PD4.
They released it in JP Amazon a few months back followed by T-Mall when US Amazon was out of stock.
There were quite a bit of negative reviews pointing out about heat etc.
You may want to reconsider your purchase decision or wait for the next gen.
sgAshton
Guys, any phone shops to recommend in the north east area that sells the iphone 11 just below MSRP?
VodkaPear
With the current choices, I guess I left with Anker powerport speed pd5? Haha
PetPet
Moderator
Moderator
If you're desperate for a 100W charger, you can consider this brand called Zendure.
Personally, I haven't used it before. I came across this brand while I was researching for chargers.
*adiBOY
I have the Zendure SuperPort and SuperTank and both are very well built. 100w on my MacBook Pro 15” on either of the charging devices.
The SuperPort doesn’t get super hot when charging in 100w.
symbiote28
i just google these products and looks like the real deal. what do you use to charge it within an hour? any problems bringing this up on a plane?
Carnage
Anyone has this problem for Instagram stories? The volume is turned off even though the phone volume is turned on and the phone is not on silent mode.
chanbri
Using the pro max and damn it's heavy!!! My wrist gonna take a beating.
Find myself favoring my pixel to use and browse. I also have the 11 and initially I can see the resolution problem when I watch Netflix. Starts out pixelated but after a while you get used to it. Watching on oled is definitely better. But pro max is heavy so watching a 2 hour show or multiple episodes is stressing my wrist.
Sent from Google PIXEL 3 XL using GAGT
Matrock5
IMO I tried out both the pro and pro Max it’s build seems v similar to iPhone X. The pro Max has some weight to it.
Aikon
If you don’t need to take photos and take videos
Iphone 11 is good enough
I don't think you can say if you don't need to take videos and photos, get the 11.
Actually I got the iPhone 11 because I hardly use the telephoto lens, even my P30P never use even it can zoom to 5x optical zoom.
So if the cameras for the wide and ultra wide angle are the same across all three models, no point spending for features you don't need.
But you should be able to take exactly the same photos and videos, just not optically zoomed telephotos.
