iPhone 12 Pro Battery Drain
linkteo
My 12 Pro Max have the same problem, overnight drained from 90+% to 67% few days ago. Last night drained from 100% to 61% overnight.
Snoweagle
Definitely not normal. Have you tried doing a phone restore? Worse come to worse restore and set it up as a new phone.
Mine if still at 100% before I sleep, 6 hrs later will still be at 100% or at most drop 1 or 2% at most.
ap6724X
I suggest you have it on Airplane Mode before you sleep. It might help
xenocide
check the apps thats having the highest batt %
try to turn of background refresh for these apps.
i'm using 12 Pro Max. i don't have such overnight drain issues.
Glariel
Mine doesn’t have such issue also, maybe SIM card is the one draining battery. probably you should try to take out SIM card to try.
metamofia89
I remember there was a suggested solution posted by Apple themselves, which requires affected users to do a full restore. I went to look for the webpage for reference but can’t find it anymore.
Edit: Can only find an article from secondary source by Macrumors https://www.macrumors.com/2020/09/30/apple-watch-iphone-battery-drain-gps/
