iPhone 12 pro max
PetPet
Moderator
Moderator
Settings > General > Reset > Reset All Settings.
Take note that settings such as your alarms etc will be reset.
StanII
U mean separate the usage report between 4G and 5G? Nope, dun have such report in my singtel app.
Yeap was referring to that
Same here on my singtel app cause my base data also not much so wanted to see if can check the usage
spidercyj
I spoken to the singtel staff before there is no distinction between 4G or 5G data limit both of them use from the same combine pool. So if you total have 50GB it is used for either 5G or 4G data just like last time when there was only 3G and 4G data only also used from the same pool mah.
Halo green
Anyone notice your brightness will auto dim when phone locked . When unlocked brightness will be max brightness . True Tone off on my 12pm
toshm200
Anyone felt warm at the back of your phone for first 10 mins when charging with Apple 20W adapter?
StanII
Hmm for their 5G VAS i was told we’re only getting 10GB, even if you apply the Data X2/3/4 plans, those only go to the 4G data capacity pool
