iPhone 12 pro max
xxSnLxx
No.. use it about 30% or 40 % will charge .. when charging always take more than 2 hours .. from 97% to 100% that 3 % can take an hours .. alright will leave optimized on then ..
Hi dreamerzz,
Has your slow charging issue solved? I am facing exactly the same problem as you mentioned.
Halo green
Anyone Not receiving notification from STraits times app?
For some reasons other apps working but not st app
dreamerzz
No .. still the same .. even 50% need 2 hours to charge.. especially the last 10% to 100 % ..will go to apple store ..
Hi dreamerzz,
spidercyj
Hmm for their 5G VAS i was told we’re only getting 10GB, even if you apply the Data X2/3/4 plans, those only go to the 4G data capacity pool
The pool is shared just that by signing up 5G you get additional 10GB. Regarding the X2/3/4 what they meant is that the X* is applied to your bundle data instead so for a 3GB plan it’s (3*3)+10 assuming you chose data x3 and 5G Vas
Barbecuepit
No. Not that gap. It’s infront upper half left side. Im reffering to the space between the screen and metal band.
Hi bro, i also have a slight gap on my iphone 12. Intending to head down to apple store this weekend to seek an exchange. Is it possible for you to share share some pictures of your gap?
striker22
I find that when I turn off the Optimised battery charging toggle, I can fast charge the phone.
Basically when on, charging to 100% take very long, good for those who charge one time overnight and ready to go the next morning.
For those who charge at random timings as and when needed throughout the day, I think best to turn this off
gregchan
Any iPhone 12 pro max users find that their screen is yellowish?
was told by an Apple Store staff that you can change up to 3 times when I mentioned abt this issue. I compared mine to the all of the phones at the Apple Store on display and mine looked too warm.
ragnarok95
Senior Moderator
Senior Moderator
Yes, seems like the pro max screen is more yellowish from 12 pro and 12. I saw a couple of time liao.
xenocide
i've changed once and the changed set also is the same. (i think i posted my experience in the other thread)
basically i went to apple store and showed them the problem.
we then tested most of the display sets. and all exhibit the same problem at the same spots. i.e. near the vol rocker area, bottom of screen
i went ahead with the change and tested on the spot with the store genius.
the new set also has the same "defects"
Darkshadows
Yup. Compared it to my Mate 20 and it sure looks more yellowish. Wonder if this is a hardware or software problem? If it's software, hope new patch can fix it. Don't like the yellowish tone. Make the phone look old like those silicone case that has aged. :(
