iPhone 18Pro/Pro Max Discussions
What colors did you choose for 18 pro?
  • Burgundy
    Votes: 35 37.6%
  • Glacier
    Votes: 25 26.9%
  • Black
    Votes: 23 24.7%
  • Silver
    Votes: 10 10.8%
  • Total voters
    93
argentinafa
Ya... Spend so much and need be bothered by such lottery. Then why spend so much on iPhone sia. They are meant to just use and forget :s13:
I can't be bothered, but still check so @kashix won't continue poloso me :s13:
But still good to know I strike the display lottery. If I strike the 4D tmr I will be happier :s13:
Those stack files created at your ioreg folders, there's no way to delete them right? No delete option.
So to conclude, this G9N panel can appear in any iPhone phone colors, any storage size, any Apple 3 sg stores.
Btw I prefer to turn on True Tone for iOS or Adaptive color tone for Samsung. I find the phone lighting emitting out, the transition is better when traveling on normal road and then suddenly entering dark kpe/mce tunnel. So I guess my eyes are more attuned to yellow/warmer tones.
Jirachi
Finally someone shares the same experience as I do 😂
kashix
Helloooo, I ask you check is for your own good! You say don’t want check, can’t be bothered, then you ownself ask me for the steps how to check the panel one horrr!
kashix
Connect to computer, sync then will be deleted I think. Alternatively is factory reset.
Rubick
This is a fact, I mean really depends on whether you want to know a not, I just share info, it’s good to know, if you not bothered by it then just don’t check ~ simi instill fear?
Joking la bro.
Mai so serious
Jirachi
Can you check if your True Tone is working with the 18 Pro Max? My screen remains white even when I enabled it.
