Better than iphone 5 ?How's everyone's battery life? Mine unplugged at 830am this morning, 4G on but everything else off, I have 25% left now at 5pm
I noticed that background apps have a larger impact on the battery life in iOS7 than in iOS6.
Having only whatsapp in the background and the phone in standby mode, I noticed the battery dropped by about 15% after 8 hours. With no background apps running, the battery dropped by 1% after 8 hours. Both tests were done right after a full charge.
Now I shut down whatsapp after using it. iOS7 has more cons than pros.
All apps can also now take advantage of multitasking to keep updated in the background. Apple has worked to optimize the practice so it won’t deplete your device’s battery life—the system will look for factors like network connection strength, time of day, and push notifications to figure out when it should update apps. And it may refresh your frequently accessed apps—social networking programs, for example—more often.
Of course, you may want more specific control over which apps are accessing information in the background. Visit Settings > General > Background App Refresh to find a list of all the apps updating in the background, as well as a slider to deactivate them. If you’re concerned about battery life, you can toggle a switch to entirely deactivate background refreshing of apps.
Are you able to see whatsapp in that list?
My guess is whatsapp is not optimised for iOS7 yet (as usual, very slow in updating their apps), so they drain the battery a lot. Close the Whatsapp in the multitasking tray to save batt. No choice, app fault.
My 5 can last full day, usually lest less than 25% when I sleep at around 12am. 5s still too early to tell going to give it a few days as I tweak the settings firstHi guys...
Just a survey on how long your iphone 5 or 5S battery last?
Can it last for one full day?
Also - do you all plug and charge your phones once you are in office at your desk?
Or it is still recommended to follow the charge only when the battery is below 20% rule.
