iPhone 6/6+ Screen Protectors
shichuanhua
I don't have ip6 :s22:
I doubt it will fully cover as curved part need some *redesign* to the sp
Btw any1 want comedown to admiralty on weekend, I would like to take some photo of the sp so will be giving 1 for free. will help u paste
edit: gave out liao
shichuanhua
since screen protector blocks front camera
just a matter of time to remove it completely becoz don't think can lift just a corner and trim
wasted $13++
:s22: what sp u use , gt no hole for front camera?
glass sp no hole okay but normal sp also no hole?
the bees
If you are using a clear type of screen protector, despite not having a cut out for the front camera, it should still be able to capture images clearly.
bockscar
Just to share. My tempered glass ($15 from P2O). It doesn't cover the entire front, presumably due to the curved screen. As a result I suspect the tempered glass doesn't press down flat against the screen. And after four days, I can like see dust particles stuck between the edges of the tempered glass and the screen. Probably the adhesive attracts and makes the dust stick on it.
I guess because mine is the cheapo one so I have this issue. Anyone else using a better quality tempered glass and not facing this issue?
liewhl
get nillkin h+ cover then
iZoneSG
I guess because mine is the cheapo one so I have this issue. Anyone else using a better quality tempered glass and not facing this issue?​
I went P2O to take a look. Didn't like the service there. The person very dao like that. As a customer its very confusing whats going on, especially when the products are all hiding behind the counter. Walked away after that.​
nacnac74
The lady (Boss??) act like people owe her money... I also walk out after a while.
ladiesman217
Who is the dao one? The guy or the lady? :D
iZoneSG
The guy lor. Not here to personal attack this outlet, I hope this feedback is meant to improve on services next time.
Anyways was fed up with P2O and went SLS and even more fed up with ripoff prices of all screen protectors and casing at SLS (28 bucks for a screen protector lolwutttt, even a random caucasian tourist passer-by tell his friend buy from internet better).
Cooled down, google a bit, revisit Burlington square ask security guard who directed me to adix shop with a more friendlier customer experience.
LIN_JOEL
nillkin h+
where to buy & price for 4.7"?
please pm me if inconvenience to post here.
Thanks
arcturuz
seems like there is no way around the curved edge screen
As long time supporters of Power Support you know that we pride ourselves on our products and we try everything possible to produce only the best. We would like to address some of the issues that are circulating regarding our new iPhone 6 products.
There are some negative reviews and comments about the new Power Support film and specifically, about the dimensions. We want to assure you that the film quality is the same as ever—spectacular! However, we had to make some tough design choices when we manufactured this product and not everyone is happy with our choice. The new iPhone 6 and iPhone 6 Plus are BEAUTIFUL devices. Part of this beauty stems from the fact that the new glass face has a slight bevel all around the device, giving a soft, gentle feel to the outside of the phone. This new Apple design presented a significant challenge for us.
On the iPhone 6, the surface of the device that is actually flat is only 58.48mm wide; however, the illuminated display area is 58.50mm wide. If we made a film that covered the entire display area then approximately 0.02mm of film would be on the curvature. This is potentially problematic as the film may bubble at the edges and eventually pull off.
This is because Power Support uses a stronger, more resilient, less flexible film material disregarding the higher cost. Some thinner and more flexible films on the market may be able to extend over the curvature, but would not provide the same protection and quality. We extended the film to cover the maximum area of the screen without compromising the adhesive bond. Our film width is actually 58.28mm wide, just slightly smaller than the illuminated display area. This leaves an exposed area of approximately 0.11mm per side. We felt that having this minimum exposure was a better alternative to having a film that might potentially peel off on the sides.
We were faced with the same problem when it came to designing the cutout around the home button. The lower portion of the home button is actually on the curvature so in order to prevent this film portion from peeling we removed it and arrived at the horseshoe design.
We sincerely thank our customers for their input and comments and we listen and take them to heart. The iPhone 6, although beautiful, has presented its share of engineering challenges. Our engineers are continuing to work on improvements and searching for better solutions to bring you the highest quality products. In order to protect your new iPhone as much as possible we always recommend adding an Air Jacket. The full, four side protection combined with the raised edge will help protect your phone and your screen.
