iPhone 6+ Wifi Problems
EldonChew
You still dont get what I mean ah :)
WiFi is so mature and apple allow this problem to happen on their newly launch iphone .. Unbelievaable.
Similar if you buy a branded notebook and you cannot connect via WiFi. Will you beleive it?
Or should I put it, unforgivable?
How can a phone call being blocked in a software upgrade release?
What is the main purpose of a phone?
Is to make a phone call.
No one ever test before releasing it to the public ?
I see..
Other iPhones iOS 7 no problem with Wifi but after update to iOS 8 have problems so someone screwed up with the software
Maybe they add too many features like handoff and stuff unlike break the wireless connectively code or something
Yeah they really screwed up with the 8.0.1 update..
b00mxer
5C user here. After days of monitoring and observation, I can confirm it's an iOS 8 issue. Tried resetting network settings and turning off wifi networking only helps for awhile then becomes slow again. No choice but to revert back to iOS 7.1.2 for now. My wifi is perfect once again. IMO, 7.1.2 is still best for now.
gniexpert3
try to set your router WIRELESS NETWORK SETTINGS, wireless channel: 2.4GHz-CH3 should be fixed the wifi problem
lawreo2002
iPhone 6 plus user here. Been using since day 1 with Asus router with myrepublic fibre. No issue. Even at master bed room. HDB.
In fact more stable than G3. Hope this helps.
Nitrile
iOS 8 is not ready for prime time. It's rushed out for iPhone 6 launch.
chardz88
i think i got this issue as well... this morning i tried to do some surfing on my 6 Plus but the page does not load although the wifi sign is still active... tried to off and on the wifi in the phone settings and it is solved... not sure if this an issue... no problem on the iphone 5 on the ios 7 so far... :s22:
wongkc
My wifi will disconnect randomly and ask for the wifi password again...
and i find that my video streaming is slow on my iPhone 6+ than my iPhone 5 even though both are on the same network...
And my keyboard click sounds seems to be very soft as compared to my other iPhones...
derrickgoh
Since iOS 8.0.2 is out, anyone bothered trying it to see if it solves the problem? Or all still busy living in the past and complaining about 8 or 8.0.1?
FreeSell
Updating My 6 & 6+ to 8.0.2 and i will observe again.
FYI I am connected to 2.4GHz Network, Using Singtel Aztech Moderm .
trento
Just downgrade to ios7 for now till theres a fix. Believe Apple allow that option right?
bockscar
iPhone 6 user here, my WIFI seems to be a bit problematic too. It loses connection from my home WIFI and goes to Mobile Data. I have to switch off Mobile Data to prevent from accidentally using up my data limit.
Sometimes it will still lose connection etc. HTC One didnt face any such problems last week.
szeli
wifi issue is still there even after update to 8.0.2.
I compared between iPad mini retina (iOS 7.1.2) with my 5s (iOS 8.0.2). On pings to same addresses e 5s always has much more latency n sometimes drops packets.
running 5ghz wifi at home.
fatangel
I can change my home router channels.
But I cannot change other router channels.
So this is not fixing the root of problem.
Moreover it is working with other devices at home all this while..
*adiBOY
I'm using a iPhone 6 Plus and I don't have any issues with the Wi-Fi. It's working perfectly for me. I'm on iOS 8.0.2.
szeli
Yeah true. Btw I'm already on e less crowded 5ghz channel liao. iOS 7 devices all no issue. lucky I haven't updated e iPads yet. :s22:
