- Aug 8, 2012
Hi kind souls,
At wits end with no idea what is wrong with my iPhone. Anyone knows any possible reasons as to why my phone is acting this way? I wish to find out the root cause of it and fix it if possible since I recently just replaced the screen. Otherwise as a last resort to back the data in my phone up and just get a new iPhone.
So here goes....
Basically, phone was working fine before SHTF.
Phone hanged, totally not responding.
Only responded to screen locks, tried unlocking the screen and got a back lit black screen.
Thereafter, did a hard reset. Reset went fine, but phone hanged again.
Then it decided to die, and now it shows a black screen only. Pretty sure there's still battery in it.
Responds to iTunes, but my phone is locked with a passcode so basically I can't back it up.
Left it for a few days for the battery to drain..
Update - Just plugged in my charger, it showed the empty battery icon on the screen.
waiting for it to charge up, hopefully it boots up so I can back it up.
Update - Basically I got it to work, and left it to charge. Came back to the same problem again...
*GRABS HAIR*
So here goes....
*GRABS HAIR*
