Snoweagle
- Sep 6, 2005
Yup. Same as airpod charging indicator. U can connect to your phone via MagSafe and see if it’s still charging in the battery status while the led changed from orange to off.
Just tested and it's working while connected to phone, can see the batt charge via the battery widget.
At first I thought my battery pack got problem but so far it's ok, only problem is it says a green light will briefly show when it's fully charged, but we're not there to always monitor the battery and usually you won't see any light. Only when removing the cable and plugging back in will I see the green light, or is there any workaround for that?
