iPhone MagSafe Battery Pack
manofsorrows
Heat and battery are not a good combination. Will wear out the battery faster especially the phone one. Unless u wanna wear it down to 80%
Snoweagle
actually you would use this battery pack knowing it doesnt charge the phone to full ?
Its purpose is to top up on the go, or top up until you can get to a charger. I don't use mine often, but it's really useful when you need it.
I can also charge my AirPods Pro too.
1982-1994
Just started to charge it to 75% after maintaining at 80% for the past one month
Snoweagle
want to check with those who are using this battery pack, how do u know when its fully charged?
does not shows any led for me..
Read HWZ Forum Rules!
It doesn't show. For me I just leave it charge and to know whether fully charged, I unplug it and plug it back, there should be a green light to indicate full charge.
But this battery pack won't take very long to charge to full even from flat.
manofsorrows
how is your use case like ? knowing that this magsafe doesnt charge up the iphone fast. and why not using a powerbank with cable but the magsafe ?
Snoweagle
MagSafe for easy attachment and carrying, some more portable. I have a main power bank, which is the Mophie Powerstation 3XL (now called Pro XL) which isn't so ideal for causing around on hand due to bulk and weight, but more inside the bag.
I don't use the MagSafe battery pack often. Sometimes when I'm on a lower batt charge on my phone when I'm out for my daily meetings, the battery pack can come in handy before I get back to the office to plug in. After that, can still charge up the battery pack.
discoburg
By the way how do you know when the iPhone is charged to 80%? You keep looking at the battery percentage of the phone while its charging?
trd2970
Anyone noticed the difference after the firmware upgrade to support faster charging?
