iPhone X battery replacement
Panerex
Hi all,
am wondering if I should replace original Apple battery, or those compatible ones at reputable mobile phone shops, due to price difference
anyone has any experience to share?
Thanks
reddevil0728
it’s like $99 by apple? Not as if it’s astronomical? Unless you can’t really afford that?
3rd party also not dirt cheap.
For battery stuff, would rather go with original by apple
szeli
I would rather go with  at $99. 3rd party u dunno what other thing they might spoil.
Apex
3rd party battery sometimes not sure how good they are. If my phone is good (except the batt) i will go for apple to do it.
almostDecrepit
I had an excellent experience getting the battery of my iPhone X at the apple store. Apart from swapping out the battery, the tech also cleaned out the gunk accumulated at the speakers housing. The wait was about 2 hours.
everex
Hi all,
Thanks
What is your battery health now? My ipx battery still at 85% after 3+ years.
netzach
go Apple Orchard to do it la.
went twice already. once before warranty was up and end Jul this year.
used iPhone X for 3 years++. still going strong lol.
Read HWZ Forum Rules!
reddevil0728
Should we change when it is 85%? Or wait till 75%?
If it’s within warranty, below 80% can change for free.
if it’s without warranty, really depends on whether you can tahan the shorter battery life. No hard and fast rule
manchow1984
My battery health already at 76% already tahan liao one day need charge 3-4 times. So can get it on the spot? Do we need to do any backup for the phone data? Btw after changed to new battery@$99 le will be good to use for how many more years?
anthonygreenisreal
can get it around 2 to 3 hours on the same day. you should always backup your phone first. I think if battery change should be able to last another 2 years of normal use.
Kunkka
Apple batt bloated on me after i changed. Using 3rd party now. If u did 3rd party repairs before dont go to apple
natsumi
My launch day X battery is also bloated. Can start to see some of the internal parts from the side.
sansanjikikut
Repaired my out of warranty XS at LYK before (motherboard issues). Apple refused to earn my $99 and change my battery, citing third party repair work was carried out before. How did they find out?
anthonygreenisreal
Coz of the parts used but the third party I think. Apple don't wanna take the risk for any issue if you swop for a third party party.
reddevil0728
cause it has been repaired before?
