iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
nagase_4
Hi! Anyone using any magnetic car mounts that mount using the magsafe?
any recommendations? Thanks!
VodkaPear
Finally psaj arrive in Singapore. Going change my case liao!
I do recommend zeelot tg too. Used the tg since first day of 12PM launch till last Friday when I change my phone to 13PM.
spuispui
May I know the original lightning cable W? If I buy a fast charging adapter, does it work with Original cable? Thx
Kusanagi
using ESR, can buy from Aliexpress/Shopee/Lazada
paired with their ESR Halo lock air armor case, very solid snap whenever i attach it
Tried it without any casing very good as well
however, i tried other (non-apple magsafe compatible) casings this morning not sure if it is due to the casing issue or the car mount but they were very weak
Case-Mate Soap Bubble
ZAGG(Gear4)
Ringke fusion was good with the ESR car mount as well
BlueBull
ZAGG(Gear4)
Does Apple Car Play work when the phone is mounted with the Magsafe car mount?
Kusanagi
i'm using wireless carplay, and it works fine
most likely a wired connection is still required if your head unit requires a wired connection
nagase_4
ZAGG(Gear4)
thanks! im using apple leather case. hopefully can mount strong.
Will buy 1 to try.
