iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
alan_shearer
i'm using wireless carplay, and it works fine
most likely a wired connection is still required if your head unit requires a wired connection
I am using wireless CarPlay as well. but I think if you are using wired CarPlay, you need one wire going into your phone (for CarPlay) and another wire going into your charger.
alan_shearer
thanks! im using apple leather case. hopefully can mount strong.
Will buy 1 to try.
ESR Halo lock is good. have been using it since ip12 series. Holds apple leather cases very well. Have also used it with ringke fusion with MagSafe. works well too.
8898108
looking for clear case with magsafe
any recommendation?
currently using spigen liquid air
leon0079
actually the iphone 13 pro magnet is strong. I was using a $5 normal clear case and the phone sticks to the magnetic holder quite firmly!
I tried to go over hump and the iphone still sticks firmly. Seems like i dont need to change to those cases with magsafe anymore.
EV1L
Was swapping between Apple leather case and the Ringke so i deduce its the clear case that causes the scratches. I need to have a case that has MagSafe supported as i am using the leather wallet and hope the Mous case magnet is strong enough.
Haha, after i put on the case, i tried removing it and dang, the magnet came out of the case and stick on the phone. Damn it. Its the smaller magnet, not the whole circle one though.
leongws
Got a Catalyst influence case for my IP13 PM. Using one with my IP12PM so go back again. Matt back or should i say opaque. The mute switch toggle wheel is easier to toggle for IP13PM compared to IP12PM. Using the color black on my sierra blue
EV1L
can charge faster meh..
No idea leh but i guess it should be the same as it should be the wattage that matters ba.
No. Anker dam overpriced. Using UGREEN
Ok, I have no experience with UGREEN or even Baseus power bricks except for their cables. I always have this mentality that you pay peanuts, you get peanuts. But i will definitely look at UGREEN
wira
Nomad having promotion at their Official store at Lazada.
anyone using Nomad case can comment if their magsafe cases magnet is strong enough ?
can use w magsafe wallets and also magsafe car mounts ?
iamgaara
Anyone mount their MagSafe wireless charger on the wall? Can share how you do it? Can just stick adhesive tapes at the back of the MagSafe charger and stick on the wall?
