Knightoftheblackrose
Thanks both. Then it don’t suit my needs. I need a charger that wont reset. Because I need to power HomePod mini plus a laptop that is connect to dongle with HDMI. If reset, HomePod mini will reset, my laptop screen to appear from the external monitor will also reset.
I believe that all GAN Chargers behave the same way.
The moment you plug in and charge using another USB Output, it will reset and recalibrate across all USB outputs.
Your other option is to purchase a separate charger, just to power those appliances that you don't want to be reset.
WeeWeeBooBooLaLa
i have this 2 chargers from Prolink. i think will suit your needs. 60W and 100W respectively. not GAN.
https://shopee.sg/-Fast-Charge-iPho...uick-Charge-PD-Charger-i.137772314.6608932594
https://prolink2u.com/products/pdc410001?_pos=23&_fid=0ea9e0894&_ss=c
the 100W one seems to have been sold out both on lazada and shopee.
VodkaPear
get non gan one if u do not want any reset
apple one works fine. the dual usb c one
https://www.apple.com/sg/shop/produ...5e7531f5142ff98609398646bf8dbdfe708ee3b7212c2
Ahh, thanks both! I didn’t know if it is a GAN chargers, it will behave like that. Learnt something new.
ok, thanks will take a look. Hahaha
