RocketBunny
I also looking at their rugged case. The non leather one
rugged case good. been using for my 14pm, can consider for 15pm too :s12:
love the concave sides, makes it easier to lift/grip the phone
and the case wont wobble when on the table due to the each corner lift
stupidog
Hi fellows, just wanna check for those who tried these 2 types, are there really a difference between the quality of screen protectors from 淘宝 versus those from say, Spigen?
taobao wans u should try "benks" or "smartdevil"
i have a whole drawer of "benks" iphone xs max to 14 pro max at home.
whole family using iphones, even small little nieces and nephews.
the quality is there... it's really good that i didnt have to change every few months.
unless u are like my careless nephews keep dropping their phones cracking the TGSP
Boiijek
I ordered but you might want to wait as the current design has a cut out for the new action button instead of a button (like the Apple cases). I ordered before realising but probably would have anyway because I wanted a leather case early and delivery is by Thursday, 21 Sept.
Thanks for the heads up! Any update from Andar with regards to adding a button? Cut out is a dealbreaker for me.
Rubick
great to hear. may hoot it during 10.10 haha
eugenetss
Now I’m confused… spigen sellers say iPhone 14pro/max camera ring protectors are compatible to iPhone 15pro/max, whereas okonz seller say otherwise. Any guru can enlighten me bcos I ordered a iPhone 15pro/max camera ring protector but the seller sent me an iPhone 14pro/max type. He insist is the same….
RocketBunny
Seems like they are going with a cutout. :frown:
(See this post comment someone asked) Hopefully they update it next time.
Bellroy one also look like have cutout on their site. (new ver leather wrap till the sides)
kelvinsin
I've been using apple magsafe clear case on my ip13 since day1, very impressive for it performance as i drop my phone once during cycling on the road and the casing protected the ip13 without single scratch/dent! And its not turn yellowish after 2 years.
May i know any cheaper alternative for apple case since the 15pro tagged as $75. After read i keen for the Caudabe lucid clear but the first batch without full button covered yet, or AMZINGthing which half price of apple but i've never heard this brand before. Or shall i just get an ugreen magsafe transparent case $11 for temporary use? Thanks for inputs!
tikokia
Boiijek
Just had a look. Looks like they’re sticking to cutout. Thats a shame, the hunt for the perfect leather case continues.. Loved the slim form factor and button quality on Andar but we move
Edit - We might see a button version of the Andar in the future it seem, from their insta
zXioNGz
Any love for Otterbox? Seems like nobody using hahaha. Not sure which one fits NT or WT lol, only the Grey Lumen sides are more transparent, others are hard color coded.
Andykaka
Wondering if the grey casing will yellow on the sides, feel like returning the finewoven and go for otterbox
zXioNGz
It will not, because it is technically not a transparent case, it’s shaded grey but more translucent compared to blue and black lumen. Finewoven if I’m not wrong it cannot touch water? Quite headache as I sometimes bring phone to toilet.
the good thing with otterbox that they came not sealed like Apple cases, so can remove and try and put back for return 😂
Andykaka
I can return my finewoven case in store right, i saw there is stocks for collection for otterbox lumen grey at orchard.
zXioNGz
Yup as long as the Apple seal not torn. If you’re collecting your iPhone in store then go there try out the cases with your new phone better haha
Fellowes
Update.
I've ordered the Mous MagSafe® Compatible Clear Phone Case - Clarity 2.0 - iPhone 15 Pro Max.
If you sign up for their emailing list, a 10% discount code is issued to you.
The case is on sale now, with a retail price of $115 instead of the RRP of $125.
With an additional 10% discount from the emailing list promotion, I paid $103.50 with standard tracking delivery of 5 to 8 business days.
Most probably I will not be able to receive the case by 22 September which is the day I am collecting my 15PM. Hopefully, I can receive the case ASAP. Meanwhile, I will have to use the phone naked.
Why is this mous clear case so expensive? Hopefully don’t turn yellowish after using.
I am thinking of buying dbrand ghost case.
singaporeguy
I ordered the Spigen Mag Armor Magfit case for the 15 pro max from Shopee. They have black and blue versions.
