kelvinsin
I ordered the Spigen Mag Armor Magfit case for the 15 pro max from Shopee. They have black and blue versions.
I only looking for transparent casing. Don’t want hide the beautiful tech of iphone itself, haha.
Was considered casetify but i unable accept their camera area black ring & company name on the casing…too much😅
decibel.
Anyone used AlignMaster GLAS.tR or EZ FIT GLAS.tR before? Which one is better??
radioshack
Noob question: is a camera lens protector necessary?
First time iphone user here
discoburg
I was sceptical initially but went ahead and pasted on my iPhone 13. Once the phone dropped and one of the protector cracked. Heng ah!
paul02
Probably not, also (maybe) unless you get expensive sapphire glass lens protector, your camera photo quality will drop.
tkl23786
I was also looking at transparent/clear cases only.
If you want top-of-the-line drop protection, you can consider Casetify and Mous.
These 2 brands have very good drop protection.
I knew about Casetify but not Mous.
I was recommended Mous here and did some reading on Mous.
The price point of Casetify and Mous are similar.
Mous specialty is drop protection and their case designs are aesthetically simple but pleasing.
Casetify offers more customisation and has many influencers and celebrity endorsements, making the brand fun and crowd-pleasing.
I chose Mous eventually as their aesthetics is more to my personal taste.
Once again, thanks to all who had recommended Mous.
Do consider Mous if you are considering Casetify.
kelvinsin
What special of mous compare to apple magsafe casing? Better anti shock and anti yellowish? I was thought apple magcase expensive enough until i see mous price tag.😅
tikokia
UAG monarch pro is better imo
edwinboon
I currently using the zeetec corning for 14PM, is quite good, i drop on concrete in carpark no damage lol.
Now the price is 39.90. But I have already ordered no brand $1.30 screen protector at Lazada Mall. Now i thinking should invest more on SP. Should I ?
HZYiLong
Any love for Otterbox? Seems like nobody using hahaha. Not sure which one fits NT or WT lol, only the Grey Lumen sides are more transparent, others are hard color coded.
Currently using the Symmetry case. The case is great but it’s hard to remove the case.
On the Symmetry model, the back plate extends to the sides, which the sides ends up with half TPU and half hard plastic. I have not drop my iPhone before, so I can’t comment how much protection it provides.
But one thing that is obvious is the front edges, not much lift, so if you’re those who place your iPhone facing down, you may want to consider other model.
Godeau
IMO, the only time i feel that warrants spending more on a screen protector is it's ease of application, like example spigen ezfit comes with those plastic alignment shroud to make your life easier.
Usually, those taobao $2 sp are very barebones and is slightly more challenging to put on your phone. However, a $2 sp means you can buy three or four at one go(to retry) if your pasting skills aren't good
我要买GTR
Rolls royce SP also bo bao won't crack/scratch and oleo coating will eventually wear off.
I rather use $2-10 SP & change once in awhile when oleo coating worn off, or kena scratch/crack.
discoburg
I have never ever tried placing SP on my own. With the jig it’s that easy? No air bubbles also?
zXioNGz
Actually the extensive price of SP nowadays for me is paying for the thinness. From 0.2mm to 0.5mm, there’s really a difference and the thinner the more expensive, for scratch resist and crack all is bull **** de hahaha. I’m still leaning towards Torres, good lasting oleo and got gift kit easy install.
