Rubick
hahaha yes, all the big sales come one after another following the iPhone launch.. :D
It will be very hard to resist with all the good deals from the USA
Let’s see got what super discount. Can add some new cases
cloudystar
Silicone better than fine woven? Never use apple case before, can share the quality and if it can protect fall? Thanks…..
Apple’s Silicone cases are probably the A Grade silicone cases but there are cheaper replica’s out there that are very good in quality too.
Not sure about drop protection though 😅
Op_Valkyrie
Cannot drop lah… got no air gap/bubble to protect. Just scratch resistant and added grip.
Charlie_Zhan
i’ve used apple silicone case in the past. and will never buy and use again. within a couple of months, the silicone around the edges will start to peel and from there on it will just slowly but continuously start to peel till you see the plastic frame underneath the silicone.
and everytime you pull the phone out of your pocket, your whole pocket will turn inside out with all the lints stuck onto the case.
i’ve replaced the peeled silicone case under the 1 year warranty and the 2nd case peeled again after 2 months. after that i just gave up and didn’t go for a 2nd replacement.
Just try loh. I using now and for this price maybe buy a second color to keep.
worse case can return within 15 days also right?
if bought from lazada can return within 15 days in unused and unopened condition.
if bought from apple direct can open and use then return and refund within 14 days. 😆
stupidog
i think apple cases only the leather wans can make it. too bad now gone. :s18:
i tried silicon cases before, damn difficult to pull out from my pants or jeans pocket and attract alot of lint.
clear case is also not worth it, any spigen, ugreen, benks, baseus, otterbox also better.
cloudystar
My sentiments exactly! I can’t stand the lint on silicone cases and the 手感 also not as nice as compared to smooth matte texture etc. It gives the sticky and dirty feeling so I can’t ever use silicon cases 😅😅
If you think about it, only Apple Leather and FineWoven package are not sealed but Silicone and Clear cases are sealed. There’s probably a good reason why they do that 😆
