Archuke
im glad i saw this video before buying rebel. didnt know the charging port only allows apple original cable....
Rubick
My ugreen cable can go in without issue.
The only issue is samsung usb c ba.
That one really quite big.
Some of my other cases also cant fit that cable.
Archuke
im using baseus pd3.1 cable. the head is quite fat. i not gonna risk $70++ just to test whether it fits my cable
galvin
But but from the video, the hole on the case really looks very small and tight.:(
Small until the 2 small screws at the side are totally covered. Can’t imagine if need to borrow friends cable to charge, use other accessories etc and the case can’t fit the cable…
cloudystar
Wow lucky i decided to hold out and wait for the Spigen Enzo Aramid
Enzo Aramid is a promising case but also one that might never reach our shores :confused:
The iPhone 14 Enzo series was not available if I rmb right..
galvin
Am looking at other sites internationally as well. Waiting for Black Friday to strike :cool:
ragnarok95
Senior Moderator
Senior Moderator
Now I buy cables I don’t buy those that stated 60w/100w/200w liao. Those only support 480mbps transfer speed. I looking at cables that can support 10Gbps liao. :D
cloudystar
I nvr really look so much into it hahaha - I just get a few slick black braided cables and be done with it! 😆😆
Computeron
huh...
1) camera ring.... u all drag ur phone across the table? I do not... n my back usually face up to show its beauty..
2) port holes... I use a 3rd party can go in leh...
3) sides flushed to SP.... he might as well say any hard object pierce thru the centre of the phone.... all sides raised 6mm also no help.
