StanII
I think the imprint is inevitable no matter what case you use (maybe less obvious on clear cases and others). The heat generated from charging will cause some sort of burnt mark eventually..
Apple first warned about it on their leather cases few years back. Even the Apple Store display phones all have some signs on imprint on the glass back.. :confused::confused:
Mine is just a MagSafe car mount, no charging capabilities, still the imprint/mark is happening.
anthonygreenisreal
Anyone have the original woven and silicone case? What your feedback?
The Apple Original silicone case is quite abit better than the rest of the silicone case you see on the market. But I won’t pay like $50 or $70 for it. For below $30, it’s not bad.
rubber33
I see. Wanted the clay colour but sold out. Maybe just wait for them to restock and also the fine woven. Currently using Andar very happy
ragnarok95
Senior Moderator
Senior Moderator
Clay silicone is the perfect match for NT iphone. That's the color i chose too. Silicone been silicone, i think any pricing around lower S$30 is acceptable for this.
rubber33
Have to wait for deal. Lazada was doing 40 dollars. But not stock now.
rubber33
Any clear case that to recommend? Apple clear case seem to have lousy protection. Maybe will try ringke or spigen
Limexx
phone rebel gen 5!
think i prefer caudabe, but can feel phone rebel gen 5 is much more sturdy and strong in terms of protection
ragnarok95
Senior Moderator
Senior Moderator
iceanger
I am using spigen clear ultra hybrid mag fit for my iPhone 14, supposedly thicker plastic that is anti yellow. However after 9 months, start to yellow already. Not as bad as the cheaper spigen clear case but definitely not anti-yellow.
terriblee
So long it’s tpu will yellow what the claim. Only polycarbonate will not yellow
cloudystar
Exactly.. the only Clear case that I know 100% won’t yellow at all is Caudabe’s Lucid Clear as there’s zero silicone/TPU used..
All other clear cases including Apple’s will eventually yellow at some parts
