ragnarok95
Senior Moderator
Senior Moderator
Not a fan of PR gen 5 frosted design. But the Aulumu one is still cheaper than the gen 5 frosted.
ragnarok95
Senior Moderator
Senior Moderator
The white one... no one knows how well the white will hold up. So i decide to go for the black. With the NT camera color, the back should look quite awesome with black.
Computeron
the drop feet worries me also... just an average drop protection... if dropped... 50% phone is going to crack...
my gen 5 if drop I not scare.
total price is $65. also steep.... think I skip, if u decided to sell, pm me.
vuzuuu
Our 15 PM charging cable can't directly plug into the hotel or airplane USB charging port, I would like to get an adapter, what do we call the adapter which allows me to do the charging using the hotel or airplane charging port?
discoburg
USB to USB-C adapter.
vuzuuu
94e8afbfd078c9c5d3bde627084ea3f9
Is this one compatible with Iphone 15 PM original cable? For charging purposes only.
cloudystar
There are risk of connecting direct to these public USB ports due to security concerns..
Consider bringing powerbanks or power adapters instead
vuzuuu
I just need it onboard for charging.
Anyway, thanks for your feedback.
ragnarok95
Senior Moderator
Senior Moderator
What's the TG that you all recommend beside spigen? Smart devil?
