galvin
Anyone using the banks armor pro Kevlar 600D ?
compare to Spigen Enzo aramid which one is better ?
Comparism between all the Aramid cases for the 15PM.
Technically Tee's reviews for both.
If you use Magsafe, definitely the Enzo Aramid for it's super strong MagSafe magnets. It picks up his charging base easy AF. It also has as a soft felt lining on the inside which the Benks doesn't.
The Benks magnet is weakkkk. Can't even pick up his charging base which i use as a benchmark.
ragnarok95
Senior Moderator
Senior Moderator
His charging base is heavy. Doesn't pick up doesn't mean the magsafe is weak when you just use a magsafe wallet thats all.
galvin
It's heavy, precisely that's why i personally use it as a benchmark when i compare MagSafe strength on cases. ;)
Not sure if there are any other reviewers out there which do similar and constant MagSafe strength comparisms.
A MagSafe wallet is mostly attached to my case, that's why i want cases with the strongest magnets to make sure it doesn't fall off when i pull it in and out of my pocket. And even more crucial when i attach a MagSafe battery pack.
ragnarok95
Senior Moderator
Senior Moderator
Benks doesn't pick up the base doesn't mean it's not strong. He already tested with a magsafe wallet and commented its strong and won't fall off. He also tested with a magsafe battery pack.
DaRRenLieW
Thank for the feedback guy! I am more incline with the Spigen enzo just that there no available stock . Guess I will kiv
frizee
Nice case, but i sold off mine already.
I find that the action button is not tactile and feels mushy on this C1 Classic case, especially when comparing to Spigens other cases.
Yeah same here but ok la, i hardly ever use it :D
discoburg
For me I sold it cause there are some marks on the rear cover.
discoburg
Just bought the Caudabe synthesis for the 15 PM at a local shop today. How come the packaging is different from the sheath case I bought from Caudabe website? The sheath case packaging open from the top whereas the synthesis opens by pulling the packaging from the right.
galvin
My Synthesis which was bought from Caudabe official Shopee store and Sheath from Caudabe US are as you described. Normal.
Synthesis packaging feels more atas to me lol.
ragnarok95
Senior Moderator
Senior Moderator
There is a brand of TG most here recommend, i forget what's the name call.. anyone knows? China one.
discoburg
Thanks for replying.
Glad that it's normal. Thought the packaging should be the same.
