Tukatuz
Good brand. Using it also.... they got a higher end glass version for 14 pro max. that one good too.. 肖特玻璃
was checking their website, don't have 肖特玻璃 fir IP 15 yet. They recommend and says 康宁 is better.
高清康宁大猩猩版 ¥64 one piece
KeYoKe
havent really try corning one before... even their normal one works fine also...
i always spam their normal ones :s13: cheap to replace too
starting i always use "more expensive" accessories, after a few months, heck care liao, just use cheap ones :s13:
Rubick
+1.
but most importantly need the oleophobic coating
ralliart12
Have you fellows use those with that supposedly-idiot-proof plastic guide? How precise is it? I never use that kind of guide before, so a bit unconvinced they can get the cut-out for the speaker grill to be positioned "centered" relative to the grill.
Cos I'm thinking, those plastic guide thingy has to have some "room" so that the person using need not force/squeeze the phone in right? If the guide has some room, doesn't that mean the phone can shift a bit inside the guide and hence the sp application can still be "slanted a bit"?
benks packaging look more classy than spigen and whitedome lol
insides, the TGSP is good quality wans. i got whole drawer of them haha
[/MEDIA=imgur]TTKKg4R[/MEDIA]
[img]https://i.imgur.com/EHkTjX3.jpg[img]
[/QUOTE]
that is y i now prefer to hoot the lazy man SP from taobao.
just put on, pull the sticker out. auto clear the dust n everything haha
ralliart12
Good buy bro. Can considered ugreen clear case too, price very value plus have magsafe ring too.
Will the magsafe strength of the iPhone be significantly weakened if I use a case without its own magsafe ring? Or depends on case thickness one?
ralliart12
康宁 is supposedly the Gorilla glass by Corning...which is the same as the the one on the iPhone itself? Anyways I do see most of the TaoBao sp listing this glass brand as a feature.
肖特玻璃....if my hanyupinyin serves me, it's Schott glass?! The one that use for art pieces? This one I'm unsure, but will be pretty impressed if they can give real Schott glass for say SGD$5
Rubick
the one i hooted is precise.
just 'clip' on your phone, it will position the SP nicely to your phone already
