swgj86
I think I like the caudabe clear design more but I last time bought one non-clear before quite cui…
Note that the buttons not covered as pointed out by a fellow forum member. I have used one before for my current ip12pm. It was very good. Didn’t turn yellow after a year of usage. After seeing MKBHD’s video, am considering the dbrand ghost case since they offer replacement if it ever turns yellow. Price difference not that significant as well. Will consider to hoot either brand in Nov.
for now, stick to the ugreen clear case I got. Waiting for my caudabe sheath (without cover for action button) to arrive.
Riguzta
I think i will use a cheapo clear case until Caudabe has the button cover and becomes readily available
don't really like Dbrand cus got black on the sides..
Archuke
wa my usb c 4k 20gbps cable came and its thick af sia . cant even fit into my magnetic cable management.
PiPiChew
Archuke
Mine just arrived. Action button cover is 1 big hole indeed, volume and power button is covered, just like what's shown on the website.
Was half hoping they rendered the pics with 14 Pro with the silent switch and actual product will cover the action button.
can you try it on your ip14 and see if its a perfect fit? there's a chance it might be a ip14 case being sold for ip15 since its technically the same.
im using the spiderman casetify for my ip14 as well and the "action button" aka the mute switch is also a big cutout
edwinboon
My ugreen clear case and $1.30 SP have arrived. Hopefully my smart devil SP arrives this Fri. Then it is really Ready for this Sat 🥳
我要买GTR
Guys the Belkin 3 in 1 or the anker cube, the power adaptor Issit 3 pin plug ah?
3 in 1 Belkin, if local set confirm is UK 3-pin plug. Belkin using classic AC adapter with barrel connectors, really turnoff but no choice. I hoped they would made it USB-C
If Anker import from USA then the wall plug will be USA plug. But Anker cube connects via USB-C to USB-C cable. So you can just swap out the wall plug to 3rd party ones.
