ratppl
Mine just arrived. Action button cover is 1 big hole indeed, volume and power button is covered, just like what's shown on the website.
Was half hoping they rendered the pics with 14 Pro with the silent switch and actual product will cover the action button.
No point getting if is a cut out
Rubick
Think I gonna pban caudabe moving forward liao. Sent them a few email over the last few days, totally no response at all.
Very different experience compared to last year.
PiPiChew
can you try it on your ip14 and see if its a perfect fit? there's a chance it might be a ip14 case being sold for ip15 since its technically the same.
im using the spiderman casetify for my ip14 as well and the "action button" aka the mute switch is also a big cutout
Paiseh. I'm Android user, this is actually my first iPhone.
USB C is the biggest draw for me thus the migration.
Also to add, likely won't fit, cause 15 is smaller but thicker than 14 by a bit. Casetify tolerance quite tight one. Each casing also comes with its own QR code and I scanned, it really shows as 15 Pro Max in the specs.
swgj86
Took them a few days to reply me as well. I guess they should be clearing backlog of emails especially from ppl like me who ordered their cases without button covers and sending them emails requesting for the complimentary ones.
But if their clear case still no cover for buttons, might consider other brands too
Rubick
Mine four days liao no respond to any email.
Got alot ppl either same day or next day reply.
Maybe see their mood
我要买GTR
They offer free gift button ver for preorder of course kena flood by emails one ma. Just wait lor.
Rubick
not just that.
Their item put ships now, also nth happened.
Previously I placed order, within 3 hrs received their email notification for tracking Liao
kelvinsin
Any magsafe clearcase <$50 comparable performance as $75 apple magsafe clearcase? Don’t want those with black edge/strip like casetify, just pure transparent. So fast seems only spigen nearest?
runforyourlife
Moderator
Moderator
3 in 1 Belkin, if local set confirm is UK 3-pin plug. Belkin using classic AC adapter with barrel connectors, really turnoff but no choice. I hoped they would made it USB-C
If Anker import from USA then the wall plug will be USA plug. But Anker cube connects via USB-C to USB-C cable. So you can just swap out the wall plug to 3rd party ones.
As in I would prefer the usual uk 3 pin plug so no choice must buy from local dealer lo
nomoneynotalk
Hi guys, I'm looking for an affordable and good-quality power bank for my IP15PM. Any good recommendations?
By the way, can a 10,000 mAh power bank provide two full charges to IP15PM? Thanks in advance!
