Fellowes
but u also can test whether it affects anything or not. calls, volume of the sound etc. if not affected then i thought it's good leh, prevent dust from accumulating there haha.
I IG PM Hoda, they reply me is suppose to be like that.
Their reply: “本來就是這樣設計的唷”
Boiijek
If function not hindered, I actually think it’s quite sick. Used to always get dust trapped there hahahah. Ordered mine on 18/9, still waiting to receive
memoriess
guys any screen protector to recommend? dont know is it me or what, but the alignment of the zeelot SP black border like a bit off.
Fellowes
You also hoda? Wait for your update see if also same design as ours. If same high chance is by design. I still waiting for them to reply me via email and have an official answer from Hoda.
wwh5210
Pated the screen protector on my 15 Pro and it seems it's harder to paste due to the curve edges this time round.
Fellowes
Where got harder? Mine put the glass on the alignment kit and press down and wait for 20sec and remove. Job done and fully paste without a single dust. All settle in less than 1 min.
remove the iPhone front white plastic and immediately prep the glass on to it. Professional, precise, quick and fast game!
Boiijek
Yeah, using Spigen first which has no issues thankfully. Will update once I receive the Hoda
Dkwj14
Can see the closeup shot on the top microphone cutout with hoda glass applied?
Mine look weird as the glass fully cover the mic cutout totally. I have message Hoda regarding this. Felt that it should invert cut that section, not doing opposite which extended that section out.
I think this is normal for the china designed ones. i saw smartdevil one also like this
their microphone side will edge out, and paired with a case that will leave a gap (e.g. the ugreen clear case). it covers the whole thing perfectly. this is zeelot with ugreen clear case
or is it edging out more than this?
discoburg
I tend to change after the oleophobic wore off, you can feel the screen protector not as smooth as before then I will change to a new piece.
The coating stated good for two years for mine. Can’t remember the brand I used
Deceased
That’s my point. I haven’t encountered any impact sound wise. And if really that’s the case, then i don’t see any disadvantages at all but rather the advantages of dust blocker.
