Rubick
- Jun 1, 2011
Just pmed uBro can link me?
Got mine from Amazon SG last week.I cancelled my Amazon SG order after learning from you all about the batch issue.
I realised Amazon SG get stock from Spigen Korea?
Anyone can share their experience with Spigen Glastr EZ Fit from Amazon SG?
can sic also. tiaJust pmed u
Also cutout for button… but looks goodthank you, looks good![]()
Ok now seeing the actual glass, can tell the alignment issue. Gap on right seems a little bigger虾皮 Spigen TG have issue? Still waiting phone delivery today, will paste and see
Same problem like me?Ok now seeing the actual glass, can tell the alignment issue. Gap on right seems a little bigger
I slap the tray on the phone lor, means the alignment of the glass to the tray in factory already got problem or something ba
See my right side:
versus left side:
Ya Loh devil n Torras.for screen protector just go to taobao and look for 闪魔 , I have been using it for many years. It comes with a tray for you to align so don’t worry if you newbie.
V similar, but only if you stare at it bah. I’m ok with this small delta but more annoyed that there is a gap for dust (using ugreen clear magsafe case)Same problem like me?
I have been using it on my iPhone 12. Cheap and the quality is decent too. Gotten Corning glass with alignment tray for my iPhone 15 Pro too. Installed in yesterday and it seems the tray is slightly smaller (maybe a bit out of shape?!) than the glass. Took the tray off and align it manually lol.for screen protector just go to taobao and look for 闪魔 , I have been using it for many years. It comes with a tray for you to align so don’t worry if you newbie.
toras tgp looks good.
open phone, straight install, less than 5 mins, did not use the wipes even
benks packaging look more classy than spigen and whitedome lol
insides, the TGSP is good quality wans. i got whole drawer of them haha
https://i.imgur.com/TTKKg4R.jpg[img]
[img]https://i.imgur.com/EHkTjX3.jpg[img]
[/QUOTE]
thanks for the recommendation; finally deployed the Benks:
First time using those tray-alignment tool. Verdict: definitely a god-send for those who find pasting SP difficult. However, to me, the end-result is still not perfect: although the edges of the SP are parallel (it's straight) to the absolute edges of the phone, the offsets on both sides of the SP (relative to the phone's edges again), are not equivalent.
I removed (lifted slightly) the SP and re-aligned manually and was able to achieve a slightly better alignment: parallel plus equivalent offset:
Oh btw, Benks also has that weird inverted "extra" protrusion "blocking" the speaker?mic?grill?:
