zXioNGz
Wow after watching few drop tests seems like the rear glass due to new design very easy shattered! Just need one pocket height drop gg liao. I’m refunding my naked skin and use Otterbox lumen case lol!
Surprisingly Black Lumen on NT is very nice looking
discoburg
Now using the Spigen thin fit for my PM. Not bad not bad just don't really like the texture of the cover. Will also try the Caudate Sheath for the first time when the covered button version is available.
By the way do the caudabe fans buy from the caudate shopee store?
cloudystar
Now using the Spine thin fit for my PM. Not bad not bad just don't really like the texture of the cover. Will also try the Caudate Sheath for the first time when the covered button version is available.
I personally buy from their online store direct as I can get up to 30% off from redeeming discount codes.
Plus buying from them now will entitle you to a complimentary button cover version case later.
The only downside is the long shipping time that typically takes more than a week to arrive.
discoburg
Plan to buy when the covered version is available.
ahsiao80
Spigen on Lazada operate by different entity?
Spigen on Shopee got stock for Glastr EZ Fit Transparent in-stock but not on Lazada.
One thing I also note, Shopee specifically state they are "Spigen Singapore" in their store materials. Whereas on Lazada only state "Spigen" in their store materials. 🤔
Take note Spigen on Lazada operates in Malaysia where else Spigen Shopee operates locally. FYI, you can use the price you seen on Shopee to price match Tech House in store price, apparently they are the same company.
anthonygreenisreal
Nice, so I can use the flash deal price for them to match as well?
Jeremy1
Who here using Thunderbolt cable for charging n transferring data ? :s12:
Stevi_Boi
anyone knows which external hdd can be used to transfer data from the iphone?
is it any hdd will do? cause i saw in popular 1tb WD $69.
and also the cable needs to be usb-c 3.0 to maximise the fast transfer speed right?
Jeremy1
about this, which is the best USB-C to USB-C cable (Fast charge and fast transfer) to get for Pro Max.
This one is very fast
https://s.lazada.sg/s.bBO6O
But the price :s8:
HZYiLong
I wanted to get from Spigen (Tech House) but currently priced at $32 ($27 after discount).
I ended up place a new order from Amazon SG yesterday 🤣 I don’t think there is any batch issue imo, it’s human error, can’t wait to paste mine to give my final verdict
wwh5210
SSD yes, HDD I don't know.
BTW for those who are looking for affordable and quality USB 3 cable do consider this local brand called ATZ. USB C to C with E-maker, 100W and 10Gbps. I gotten this https://atz.com.sg/shop/cables/usb-cable/usb-3-2-cablestype-c/atz-usb-c-mm-xm/. It's available on their official web and Lazada.
icecubes
Just switched over to IP15 pro.
Do you guys buy camera lens protector? Wondering if i should get it
Archuke
thanks for the recommendation; finally deployed the Benks:
First time using those tray-alignment tool. Verdict: definitely a god-send for those who find pasting SP difficult. However, to me, the end-result is still not perfect: although the edges of the SP are parallel (it's straight) to the absolute edges of the phone, the offsets on both sides of the SP (relative to the phone's edges again), are not equivalent.
I removed (lifted slightly) the SP and re-aligned manually and was able to achieve a slightly better alignment: parallel plus equivalent offset:
Oh btw, Benks also has that weird inverted "extra" protrusion "blocking" the speaker?mic?grill?:
zeelot solidsleek dont have that issue. it follows the design of the mic grills.
