VodkaPear
Wish I knew about this earlier. Just took a closer look and my 14PM has some scuffs from me jamming it in blindly. :cry:
I used this also, but bad exp. cuz the sticker bua tio my case and lifted out then stuck some sands. When I found out, it was too late. Caused more scratches than protecting it. Hahaha
kuma-mon
Does anyone iphone 15 feels warm when charging?
Im using u green 65w charger
Scared will deplete battery life overtime
Or should i use a lower wattage/slow charger??
EV1L
Hi, Is rhinoshield case good and where can i get it locally? They have one piece anime design which looks nice.
garychengjw
title_iphone_67p_2023__ultrahybrid_magfit_zeroone_white_77406658-c313-44cc-b7f9-f95e6401b3e7_500x@2x.progressive.jpg
iPhone 15 Pro Max Case Ultra Hybrid Zero One (MagFit)
suggest can monitor on amazon sg.
fakebran
Does anyone’s Spigen Max Hybrid case squeak below the volume buttons? Mine seems have some room at that area, resulting squeaking/moving when pressed on. Not sure if it’s because I open and remove the case a number of times (quite hard to remove)
kuma-mon
I think limited ones like one piece need buy from official site
But i would recommend casetify ones, the one piece designs nicer
paul02
Even with that, you could still scratch the sides especially if you’re in the dark and trying to find the hole. Unless you 99% of the time hit around that area of effect.
BlueBull
I bought the inexpensive Lionshield clear cases and tempered glass protectors from Lazada and received them before IP15PM pre-order day. Idea is to use them until my Casetify cases and arrive and I was browsing for Spigen screen protectors online.
Now that I have the Lionshield protectors on my IP15PMs, I will be keeping them on. They are good. Very value for money with good quality. I am using the Clear Premium version, $7.90 each before vouchers.
For those who don't want to pay $20+ for a piece of screen protector, can consider this.
My IP13PM is using $10 privacy tempered glass protector that came with installation frame, also very good.
Really no need to spend so much on screen protectors if you can find good quality cheaper ones.
Lime89
When it reaches mu vpost warehouse i will update on final price to buy from anker official webside. Paid $174 sgd for the cube. Now waiting for shipping charges
@caesium2108 not sure if you are able to cancel and re-place your order. Sounds like you got the 15% off using code "WSAPPLE15".
There's a special code "ankerlive1" for 20% off the Anker 3-in-1 Cube with MagSafe (you can find more product-specific discount codes if you replay their live stream), or up to 25% off if you buy 3 products:
Buy 1 to get 15% off, buy 2 to get 20% off, and buy 3 or more products to get 25% off.
Your discount is applied automatically at checkout:
15% Off Code: WSAPPLE15
20% Off Code: WSAPPLE20
25% Off Code: WSAPPLE25
