paul02
First time trying a magnetic wallet for iPhone...dang the magnetic lock is strong!
rashcrash
Any MagSafe wallet that I can use on MagSafe car mount? Meaning I can still attach phone to MagSafe car mount with the wallet in between
jermx9
Took out my case for awhile and realised how good it feels to use it without a case. NT really looks and feels good on its on
我要买GTR
I highly doubt have a product of such calibre. Probably need an electromagnet to hold both wallet & phone 🤣
fateless
I'm using the Belkin BoostCharge Pro Flex USB-A to USB-C cable.
It's a little on the expensive side but it's USB-IF certified with a 5-year warranty. I've tested it to work with CarPlay + charging at the same time.
I bought it because another cable I have doesn't work at all. This is listed on the Apple Store, so I figured there's a pretty good chance it works. Didn't buy it from Apple though cos they only had the white one 😂
A little worried that the rubberised texture on the connector heads would become sticky over time in our climate, we'll see.
Comes with a nice magnet to keep the cable routed away from the cup holders and gear stick.
MagSafe car mount pictured here is a mophie. They have the charging and non-charging variant and you can use it with or without an extension arm so you have options to position the phone in a way that it doesn't block the CarPlay screen. I bought the non-charging one as my car doesn't have wireless CarPlay.
Hope this helps!
thanks. Will buy the Belkin cable.
trd2970
Haven’t come across but u doubt there’s any
You can actually just remove the wallet easily when in the car, put in your pocket
paul02
Wow this wallet comes with Apple Find My?!
Yes! That’s why it’s more expensive.
It could double as a “card wallet” as it has space for 3 cards.
Currently using 2 cards…no slot to hold my cash though.
