iPhone16/Plus/Pro/Pro Max Accessories Thread
kmkimlo
Bro the Belkin i linked to is GAN leh.
https://www.belkin.com/sg/p/dual-us...with-pps-65w/P-WCH013.html?isPdpRedirect=true
My macbook going to bye bye soon once M4 Mac Mini comes out. So its just ipad, iphone, watch & airpods. The last two no issues lah low wattage devices. Ipad i seldom use so don’t need to charge it concurrently with other devices.
The two devices i use daily & need to charge concurrently to save time is phone & watch. Which that Belkin can handle what. Port 1 with sharing is 45W which is exact wattage for IP16 PM’s max 45W and port 2 is 20W which is a little over Watch 10’s max 18W.
And if a future iphone require up to 65W i can still use this Belkin just not charge 2 devices concurrently cos port 1 alone without sharing is 65W.
okies. if there is no intent to bring any laptop out, then thats fine :D
for my case, i am in charge of charging many many things for the fam. so i have multiple 100w, 1 160w gan whenever going overseas :s13:
ragnarok95
Senior Moderator
Senior Moderator
Belkin. I only own their surge protector. Everything else are ugreen for me. My display port cable, internet cable, usb c cables, usb c docking, charger are all from Ugreen. Powerbank is Xiaomi. :s13:
VodkaPear
Mine all ugreen. From hdmi cable to charging cable to Gan charger, usb c hubs, usb c adapters. Only powerbank is Xiaomi. My phone case also ugreen. Hahahaha
runforyourlife
Moderator
Moderator
Me too! Only the extended power cable from Belkin hahaha
evilduxy
if the device max charged at 45w only so tt means my current 65w is enough? cause i've only use it to charge 16pm n earbuds only max so no need to buy another 100w i think?
KwayChup
The answer it it depends, some charger like Ugreen has C1,C2,C3 and usually the top port takes priority in providing the highest wattage available. The phone will negotiate itself with the charger so not much to worry. TLDR, if worry that you cannot get the highest wattage charging input, get 100W or 200W kind usually most of their ports are capable of pumping up to 45W on each port.
At the end of the day, its just charging faster or slower, nothing much to worry about.
kashix
Problem is your charger can output max 45w boh, usually lower or split when you charge multiple device. Unless is those 1 port 45w ok la
garychengjw
Between anker, ugreen & belkin, seems most feel belkin is “safer” no?
being using the ugreen nexode 100W charger since launch. rly no horse run.
then again, if you wan buy well known brand. so be it, we are just recommending.
at the end, no electronics are deem safe. see your luck only.
garychengjw
just get 100w charger to "play safe" / "future proof".
the price gap not that huge by looking at the ugreen ones.
