iPhone16/Plus/Pro/Pro Max Accessories Thread
DaRRenLieW
Does the camera size same as iphone 15? I have the camera lenses glas from Spigen last year. Left one more inside. I look at the current listing it shop for iphone 14-16
spyder81
I used caudabe sheath for my iPhone 15 PM. Dunno why the lips especially at the corners seems to expand/ become loose. Can see the gold color of the phone frame. The corner will comes off the phone when push it slightly.
It was tight fit when I first used it. Not sure is it our weather. Anyone encounter the same? Now I reluctant to buy caudabe again and if drop now, the phone sure pop out from the case one.
No leh mine still tight and fitting maybe you keep taking it off that’s why. Mine went thru all kinds of weather and abuse.
leongws
I don’t really remove the cover from phone leh. For the past 11 months since I got the case, removed less than 5 times.
cloudystar
Been using Caudabe for the past couple of iPhone generations , but will wait for them to come out with a camera button covered case.
Already got the Apple silicone case to use in the meantime.
I have doubts to whether they’ll release the camera control cover button version this year.
The action button last year was a much simpler engineering. In this case, they need to use sapphire crystal coupled with conductive layer to communicate finger movements to the camera control button.
Perhaps they’ll include that for iPhone 17 instead. That is if we don’t see a camera control-gate issue 🤣🤣
DrAwkward
Anyone knows if the front screen for IP15 and IP16 are the same?
i.e., the front camera/dynamic island location.
Edit:
From Apple store, should be same?
GrizzlyBear
Do you both of you use MagSafe wireless charging?
I do with my Apple silicone case and noticed this issue happens fast, within weeks.
GrizzlyBear
Not really I use smart devil Corning glass, cheap and good. Never go back to Spigen already using this.
do smart devil screen protectors have the protruding edge at the top above the speaker grill? I chat with the seller on Lazada and they replied (in Chinese) that most of their products have that.
