iPhone16/Plus/Pro/Pro Max Accessories Thread
KeYoKe
waiting for my skin and i'm done for the year.
Where u get the imos bro?
Deceased
SRSworks (from HK), but get directly from TW or wait for MY to release it for cheaper cost ba. If you are getting the exact one, need to take note it's the sapphire version, not the normal one (9M vs 9H).
sneggg
I bought the apple silicon case and Belkin sp from apple.
The sp they actually have a tool in the shop for applying and they mention have 2 years warranty can ask for replacement when cracked not sure if it really works as intended though but good to know.
don’t really have good esp with the asc as previous ones always peel but not much options currently. Haha
KwayChup
The 2 years warranty isit written anywhere or just a verbal thing mentioned by the staff? If really crack can change is really worth it
sneggg
There’s a QR code in the package where you scan and register.
Yea I felt better after hearing that. Haha. They say they will send you the replacement you can either apply yourself or go to apple to do it
you think 60 is exp but there’s a que just to paste this sp at the store. Lol
SeanPC
The sp sometimes will crack when drop. Can change how many times in 2 yrs? If 3 times and more then worth the price.
Deceased
I can buy those 3 round camera lens to go with the ASC right? Those round ones that come with diff colours.
You can..but generally if u are using a case already, there’s really no need to apply the lens protector as those lousy ones or when not applied properly will affect the cam quality.
kashix
I’m using the ugreen full coverage with black border with ugreen clear case, ok leh. I feel it’s pretty good. How do I check if the glass is actually blocking my content? First time using ugreen glass with their case, very seamless.
luckygal
Ugreen case my fren using too. He said not bad. Just that the camera action button not covered.
sneggg
Good deal. Can get it.
Yea sounds like it but not sure in reality if it’s difficult to get a replacement.
Down to individual some prefer a less exp one and change every few months or so
