iPhone16/Plus/Pro/Pro Max Accessories Thread
andylee1986
i dont want to use my clear case already, slippery and buttons hard to press.. a bit regret buying
garychengjw
Found it but also no camera button protection. Was trying to look for one that has both.
at this point of time, only Supcase or apple silicone liao. Gotta wait again like how last year action button coverage.
SeanPC
All the IP16 cases from taobao currently only have a cutout hole for camera control. I think need to wait a few months before cases come equipped with the hole covered.
Get 1 to use first unless get from apple.
Kyubi
Can see YouTube review for the apple case. It is a sapphire crystal layer.
oo looks like only apple case or limited 3rd party case have this layer that covers the camera button… maybe have to wait a bit longer for them to update
Crayon Shinchan
Went to refund the Otterbox Lumen case. The edge of the case finishing not very good. Abit sharp and uncomfortable when hold.
they didnt polish properly.
Shadow04
I’m using the ugreen full coverage with black border with ugreen clear case, ok leh. I feel it’s pretty good. How do I check if the glass is actually blocking my content? First time using ugreen glass with their case, very seamless.
Just launch the camera app, there are white right-angled lines in each corner, if you can see the full lines in all 4 corners should be okay liao.
My SmartDevil Privacy blocked the right most line, so it means part of the screen protector’s black border is blocking the phone screen.
kashix
Mine can see all 4 but I get what you mean, yes means mine got block portion of the screen but nvm, I think still looks pretty good to me! Thanks bro! I compared with my iPhone 15 Pro Max, the lines more obvious on that.
Rubick
Just applied Hoda sapphire glass, blocked very slightly, if I look at it from an angle still can see the line
Rubick
The back portion right, mine abit rough.
now thinking whether to just yolo with the Supcase instead.
Crayon Shinchan
Yes the edge abit rough. Sharpy feel. Not comfortable. I went back to see the other lumen also similar but all the roughness varies. Seems like QAQC not very good. Decided to refund the $75.
actually after I touch the supcase button don’t think it is that bad to scratch the camera button. the button should be stationery after you put in. Unless keep take in and out?
The camera button is make of sapphire crystal I think?
