iPhone16/Plus/Pro/Pro Max Accessories Thread
luckygal
If I buy the ugreen screen protector what comes with the auto alignment frame, can I use the frame for future screen protectors that do not come with the frame?
ragnarok95
Senior Moderator
Senior Moderator
Buy back the same glass.
Kyubi
Likely can … should fit other sp of the same iPhone model
Jirachi
nobodi buy those small protection for the camera lens?
I personally won't. Make cause lens refraction.
The camera lens seems to have the same sapphire coating as the one on the Apple Watch Ultra. It is quite scratch proof.
illusion00
I bought the ugreen tempered glass with black border for pro max...it doesn't seem like a full fit even with the guide to paste. My issue is the top doesn't seem to fully covered.
Anyone experiencing the same issue?
Crayon Shinchan
u got order right? can test it out.
Feels sturdy and solid, my only irks is with the camera capture button.
It is 'shaky', probably designed this way so that you can scroll the button to zoom in and out when using the camera.
It is not as intuitive as the Otterbox Lumen for sure.
I returned before I receive the phone.
garychengjw
