iPhone16/Plus/Pro/Pro Max Accessories Thread
kruzeryo
I decided to go to Tech House and change the tempered glass to Spigen Glass Ez Fit. No border. Much better now.
ragnarok95
Senior Moderator
Senior Moderator
For iphone 16 p/pm, the best tempered glass is still the one without black border. I know some will disagree with me, but considering how thin the bezel is for 16 p/pm, going the non-black border route is still the best choice.
Op_Valkyrie
What you think about Belkin ultra glass 2? Worth the hoot?
Using ugreen TG now, got border and you are right, it’s eating alittle of the screen due to this year iPhone pushing the screen estate to the max.
ragnarok95
Senior Moderator
Senior Moderator
From Apple right, heard got warranty, machiam like TG apple care hence S$60. :s13:
If you are happy with the ugreen quality, then just get the Ugreen one the above bro shared. Else, you can choose Spigen one. I am currently using the Spigen one. S$25 from amazon, 2 piece.
https://www.amazon.sg/Spigen-Temper...refix=spigen+iphone+16+pro+max,aps,333&sr=8-1
Op_Valkyrie
actually my concern is which borderless TG is pushing to the edge (edge to edge) without a big gap between which most borderless has. Also thickness matters, so far Belkin one seems thinner…. 🤔
ragnarok95
Senior Moderator
Senior Moderator
Mine got a gap about 1mm or less, same as kashix.
VodkaPear
Same concern. That’s why hope some bros can share the pic with borderless and with case like ugreen kind.
Cuz diff ppl diff expectation.
