iPhone16/Plus/Pro/Pro Max Accessories Thread
BradenHeat
Loving the torras oStand + Ulanzi MA30 Carabiner-Mounted combo
for those gym rats torras is imho much better all rounder case with in built rotation ring
xSupremex
Just spend $64.95 to get the Belkin tempered glass at orchard Apple Store and staff applied for me. 1st TG fail cause got a small bubble cannot be wipe off. 2nd one works great and I think the money is well spend. Excellent fit and super clear and smooth.
AngelRomeo
Just spend $64.95 to get the Belkin tempered glass at ion orchard and staff applied for me. 1st TG fail cause got a small bubble cannot be wipe off. 2nd one works great and I think the money is well spend. Excellent fit and super clear and smooth.
iStudio? $64.95 for a screen protector is too expensive
AngelRomeo
Typo, in Apple Store orchard road. The official Belkin ultra glass 2 they selling
i used to go istudio to paste tempered glass for like 59.90ish that kind, paste liao also like very clear and smooth
then as years goes by, i feel that it is just a normal glass and the oleophobic coating can wear off
now i get those cheapo tempered glass that can protect the screen can liao
ragnarok95
Senior Moderator
Senior Moderator
The same Belkin glass is going for S$2X in Amazon. The only diff is no one paste it for you and if you screw the first time, you need to buy another piece which still work out cheaper than Apple store.
But i heard members here said you can go back Apple store for replacement? Did you confirm with the Apple staffs there regarding the warranty?
xSupremex
Warranty is claim directly from Belkin, not from Apple Store.
The safety guard was the product had defect and the apple staff replace another one for me on the spot, that’s the only saving grace.
ragnarok95
Senior Moderator
Senior Moderator
Thanks for confirming that the warranty is claimed from Belkin. So same as the one in amazon too.
evilduxy
anyone got any kind of matte/bluelight sp tt doesnt have black border to recommend?
now using the esr tg but like got leave some fingerprints see liao abit gao wei
Jirachi
I am waiting for matte no black border too.
|XcElLeNcE|
I peeled my Belkin off and returned it back to Apple. The SP is a dust magnet and after wiping it off, the adhesive at edges kinda comes off like those from Whitestone UV SP affecting the adherence to the screen. Went with SmartDevil instead.
ragnarok95
Senior Moderator
Senior Moderator
Woo... You mean u take the Belkin glass off, put back in the box and return back to Apple for a refund?
Limexx
apple store tell me belkin if got issue can claim with belkin but get replacement at apple store. not sure true or not
xSupremex
The apple staff told me, warranty claim directly from Belkin. During the warranty registration, there is 2 option:
1. In-Store Installation - Belkin will mail over the same screen protector and then you bring it to apple store to have them paste for you.
2.Self Installation - Belkin will send over the screen protector with DIY tool for you to self paste at home.
ragnarok95
Senior Moderator
Senior Moderator
Maybe can buy the glass from Amazon and go Apple ask help you paste. :s13:
iosnewbie
Will the rotating ring get flipped out when detaching the case from a MagSafe charger?
