iPhone16/Plus/Pro/Pro Max Accessories Thread
caesium2108
anyone using the caudabe paragon series? never own a caudabe case before.
Which brand would have the strongest magsafe magnet in your opinion?
Thanks!
galvin
Thanks!
Last year the 2 strongest MagSafe magnet strength brands were Spigen and Caudabe.
Spigen Enzo Aramid was stronger than Caudabe Synthesis.
You can watch Technically Tee’s YouTube channel for his MagSafe strength testing for the various brands
caesium2108
ok thank you!
cloudystar
Those two are actually cases with super strong magnets.
Other than that, most MagSafe cases do have sufficient and competent magnet strength.
cloudystar
Thanks!
The Caudabe Paragon is an exciting new case but I think most people haven’t manage to get their hands on one yet.
I ordered 3 weeks ago from them and it hasn’t even shipped yet 🥲
yocoolboy
Hello wondering if anyone is using otterbox lumen + smartdevil/ugreen black border tempered glass combo for iphone 16 pro max? Does the case touch the TG and lifts it up with a bubble? TIA
Jirachi
You can head down to an Apple Store to try this.
xSupremex
Used to go to p2omobile to get our TG pasted by the shop owner uncle. But since nowadays a lot of brand release those DIY tool kit, don’t see any need to visit their retail anymore.
iosnewbie
I used visit a shop at Bencoolen (can’t remember if it was p2o) to stick TG. After a few incidents where I damaged the TG which costs around $30 5-6 years ago, then I decided to buy those fairly cheap ones online and DIY applying even without those tool kits.
cloudystar
Anyone good full coverage sp to recommend without blocking the borders of the screen?
For non-black borders sp, all these 3 types are good options depending on your willingness to spend
Ugreen Screen Protector Glass
Spigen Glastr EZ Fit
Belkin Ultraglass 2
Aaron_liu
Belkin Ultraglass 2
Ok thanks for the recommendation
Are these full coverage? Will there be dust particles stuck at the edge of the sp after some time?
